Brooke Posted February 9, 2008 Share Posted February 9, 2008 VectorScript editor confirms that plug-ins I have added are being installed but I am unsure of how to access them. Do I have to map them to the workspace for access and/or is this generally done automatically as a part of the script? The icons presumably distinguish among the types of plug-ins in the editor(Help says "The three types of plug-ins ? menu commands (.vsm), tools (.vst), and objects (.vso) ? allow scripts to integrate into both workspace menus and tool palettes, as well as other VectorWorks features such as the Resource Browser.") Tips appreciated. Quote Link to comment
islandmon Posted February 9, 2008 Share Posted February 9, 2008 VW recursively scans for all the available Plug-ins, but only Loads those selectively installed via the Workspace Editor and linked with each specific active Workspace. This allows for minimal conformation of Menu-Tool-Object Plug-ins necessary to suit any given project. A worthy concept, but in practice I suspect that most Power Users just load everything onetime and manipulate them via the various Tool Palettes. Quote Link to comment
Brooke Posted February 9, 2008 Author Share Posted February 9, 2008 (edited) Thanks, mon. And the easiest (or only?) way to load one time is to map them to the workspace (which looks like a mouthful, given the vast nested hierarchies and choices)? Is there a quick way to get them into the workspace? When you say manipulate them via the tool palettes you mean invoke them there, rather than configure them? Does the real configuration, the placement of the plug-in in the particular tool palette, for instance, have to be accomplished in the workspace editor? VW recursively scans for all the available Plug-ins, but only Loads those selectively installed via the Workspace Editor and linked with each specific active Workspace. This allows for minimal conformation of Menu-Tool-Object Plug-ins necessary to suit any given project. A worthy concept, but in practice I suspect that most Power Users just load everything onetime and manipulate them via the various Tool Palettes. Edited February 9, 2008 by Brooke Quote Link to comment
islandmon Posted February 9, 2008 Share Posted February 9, 2008 Yep .. using the Workspace Editor as a portal to config the various existing WorkSpace palettes and to create new palettes for specific purposes. For example, placing authored Tools into each individual authors own palette. Or all Roadway Tools into a separate Roadway palette. Rendering Tools into a Rendering palette. There's no law that says duplicate Tools can't occupy multiple palettes & menus. Mix & match ... depending on your particular style of work . Quote Link to comment
Brooke Posted February 10, 2008 Author Share Posted February 10, 2008 Thanks again. It's the hunting and pecking looking for newly loaded plug-ins that looks to be tedious, and then of course the figuring of where to put them. Seems they should go somewhere by default, as specified by the writer. Quote Link to comment
Pat Stanford Posted February 10, 2008 Share Posted February 10, 2008 If the writer bothers to give them a group then they will go to a folder with that name. If not, then they just go alphabetical. Pat Quote Link to comment
Brooke Posted February 10, 2008 Author Share Posted February 10, 2008 That's helpful. Thanks. Quote Link to comment
