Cable Rails = Long Render Time
J Lucas
I created a 3D model of cable gaurdrails, on a porch and two decks, on a house I am designing. I used solid extrudes and sweeps for the components. After adding these railings to the model it now takes a very long time for hidden line to render. Did I do something wrong? Should I convert these objects to some other type?
Editing the history should work. I'd use rectangles because you will end up with less lines in your Hidden Line Render.
The other option would be to use nurbs. Sweeps in particular can be faceted in Hidden Line Render views. draw an arc path and use Extrude Along Path instead. Try that first on just the sweep parts and see if it makes a substantial difference.
Another good trick is to use symbols for repeated elements.
