digitalcarbon Posted January 22, 2008 Share Posted January 22, 2008 please see attached. picture "corner" shows pink lines and black. black is wall pink is 2d guides if i set the bottom of wall opening to the bottom of my guides then i cannot get the top of my wall opening any closer to my guide than .039" we need to be able to have 90˚ or more w/ the wall reshape tool. Quote Link to comment
0 islandmon Posted January 22, 2008 Share Posted January 22, 2008 Placing 3dLoci facilitates reshaping Quote Link to comment
0 Dieter @ DWorks Posted January 22, 2008 Share Posted January 22, 2008 But it will never be 90?. It's just not possible with walls. Quote Link to comment
0 mike m oz Posted January 22, 2008 Share Posted January 22, 2008 DWorks, you are correct in that you can't get verticals if you manually reshape - they will always be off vertical by exactly 1 mm at a scale of 1:100. If you use the Fit to Roof method (aka Geometry) you can get an exact vertical edge. Therefore if you have to have exact vertical edges use an extruded profie on a temporary layer and then use the Fit to Roof Command. In the example shown above you would choose the bottom of the wall to fit to the geometry. Quote Link to comment
0 digitalcarbon Posted January 22, 2008 Author Share Posted January 22, 2008 mike m oz, thanks for the thought but, no way! i tried to build a 3d fire place & chimney and it was way too complicated. i am not going to add more complication to it. Quote Link to comment
0 mike m oz Posted January 22, 2008 Share Posted January 22, 2008 (edited) Using the Fit to Geometry method is often quicker. The bonus is it is precise. Edited January 22, 2008 by mike m oz Quote Link to comment
0 digitalcarbon Posted January 24, 2008 Author Share Posted January 24, 2008 now your talking! great idea! Quote Link to comment
digitalcarbon
black is wall
pink is 2d guides
6 answers to this question
