chstech Posted January 7, 2008 Share Posted January 7, 2008 Hello all, I have done the following, used the angle tool and created the size I wanted, then Convert To Group, then I extrude that to 4'. I now need to make the ends have a 45deg angle. I have tried to Trim and Clip Surface, both did not work. Help? Did I even create the 3d Angle properly? Is there an easier way? Thanks in advance Quote Link to comment
mike m oz Posted January 7, 2008 Share Posted January 7, 2008 Use the Split tool in the Split by Line mode. Discard the piece you don't want. Quote Link to comment
chstech Posted January 7, 2008 Author Share Posted January 7, 2008 Thanks Mike!! I knew it could be done, just didn't know how! When I made the angle 3d, did I do that correctly or is there an easier way? Thanks Again Quote Link to comment
mike m oz Posted January 7, 2008 Share Posted January 7, 2008 To ensure the angle is at 45? and the resulting face is vertical you need to do the split in Top/Plan View. Quote Link to comment
chstech Posted January 7, 2008 Author Share Posted January 7, 2008 I got that, I ment creating a 3d piece of angle iron! or tee or channel for that matter Quote Link to comment
mike m oz Posted January 7, 2008 Share Posted January 7, 2008 Your method is the best way of creating the base 2D structural shapes. Quote Link to comment
chstech Posted January 7, 2008 Author Share Posted January 7, 2008 Thanks again !! Quote Link to comment
