Gytis Posted January 3, 2008 Share Posted January 3, 2008 A little problem with 2008, must be some local setting. Viewports display in Wireframe even when set to Hidden Line or Dashed Hidden Line, UNLESS the "None" class is visible. Then all is OK, except I don't want "None" visible... Quote Link to comment
Guest Posted January 3, 2008 Share Posted January 3, 2008 What is the build number of your VectorWorks? (VectorWorks > About VectorWorks -> the number in parenthesis) Quote Link to comment
CipesDesign Posted January 3, 2008 Share Posted January 3, 2008 Most current build is: SP2 (82613). Updater available on the downloads page.... Quote Link to comment
Gytis Posted January 3, 2008 Author Share Posted January 3, 2008 (edited) Very interesting...I installed SP2, and it shows up.....(see file)...but build is wrong???? Also, did "Check for Updates..." and all is cop-acetic? :confused: Edited January 3, 2008 by Gytis Quote Link to comment
CipesDesign Posted January 3, 2008 Share Posted January 3, 2008 This is because NNA have not updated the "current build number" in the check updates on their end. I'll bet if you go to "About VW's" you will find the correct build number. Katie, will you ask Charles (or someone) to fix that, pretty please? Regards, p Quote Link to comment
billtheia Posted January 3, 2008 Share Posted January 3, 2008 Mine shows up as Build 82099 too. I installed SP2 a couple of days after it was released. What the...? Quote Link to comment
Guest Posted January 3, 2008 Share Posted January 3, 2008 Another update was since the original SP 2 release addressing a few outstanding issues. Quote Link to comment
Gytis Posted January 4, 2008 Author Share Posted January 4, 2008 Right-o! Have it all sorted out now with Build(82613). Now I can use the happy emoticon. Now if NNA could just update their updater, all will be well in the world. And it was the holidays, so.......a little tardiness is in most people's lives. Thanks Katie and Pete. Quote Link to comment
