Layer & Class Visibility
Jim Smith
4 answers to this question
PS, if classes aren't convenient for you, you can copy the viewport in question, and turn off all of the layers except the demo layer and then override all of the classes to dashes at once. Then, by stacking the copied viewport under the orignial (turn demo off in the original),you'll get the look you're after.
It's a small work around, but effective.
I didn't read Taproot's post, that workaround may work. Thanks.
Peter, the prob. with your suggestion (if I understand) is other dashed lines & walls with components are also altered.
As a suggestion I still would like to have a Class/Layer "DASH LINE" option as grey does not really work that well on our laser printer. While the opacity of layers is an improvement, this would also better as a Viewport option.
