survey input not working??
land1
I am trying to create a small site model using polyline contours as base information.
I have followed the instructions to the letter (I think)but have no result.
I have converted the polylinnes to polygons - in the aec pull down selected survey input>2d polys to 3d contours.- set a start elevation and interval (500mm for the small site). Now when the set elevation box comes up no contours are highlighted and the process comes to a halt.
What am I missing - I have successfully created site models before in this manner.
I think the problem is that there are object on the layer other than the polygons. Try copying the polygons to a new blank layer, set the Layer Options to Active Only, and try it from there.
If you have to cancel in the middle, it will still create a partial object, which will mess you up the next time, so delete all and paste the polygons again.
Pat
