Larry B. Posted August 13, 2007 Share Posted August 13, 2007 Is there a method to increase the spacing of balusters on a metal handrail? I wanted to use pipe for the handrail with 1 intermediate rail of the same diameter, but have the balusters spaced 48" apart, not the maximum of 11" that the program requires. I'm using 12.5.2 on Vista. Thanks, Larry Quote Link to comment
CipesDesign Posted August 13, 2007 Share Posted August 13, 2007 Larry, if you use the "handrail straight" object (in the furniture/fixtures tool palette) you can adjust the spacing to whatever you want by typing the value into the "upright spacing" field in the OIP. HTH's Quote Link to comment
