jchan Posted May 3, 2007 Share Posted May 3, 2007 I'm working in a small London base architectural firm, 9 staffs, we have our own simple classes & layers setting for the small jobs, but now we are growing bigger & bigger, the current setting seems not be able to handle the large job, so I want know, anyone using the default standard AEC(UK), if you do, what's the pros & cons for using the default standard? I downloaded the list of AEC(UK) from http://www.aec-uk.org/ but the name of the classes they seem a bit different than the VW set up, not sure does nemetschek have the lists & descriptions of AEC standard? many thanks Quote Link to comment
Christiaan Posted May 3, 2007 Share Posted May 3, 2007 They do appear to be different don't they. In any case I couldn't imagine working in a file with a Class structure like AEC (UK). It'd drive me nuts. We use full length Class names, such as: Shell-Walls-External I don't see the reason for most abbreviations in this world. Why do people abbreviate so many things? Down with jargon and abbr. I say!! We could map our template to this standard I guess but there doesn't seem to be any reason/demand to, not with the consultants we work with anyway. Quote Link to comment
jchan Posted May 4, 2007 Author Share Posted May 4, 2007 Thanks Christiaan, I tried to use the AEC standard yesterday, it seems too complicated, and you need to remember all the code in order to draw fast, it's such a headache, I will try to expand the current setting a bit, I think the "Major-Minor-Status" stucture works well, at least we have been worked on this stucture for years, and those are important for 3D modelling as well, Quote Link to comment
