radgivaren Posted April 26, 2007 Share Posted April 26, 2007 Hi! Just recently started using VW 12.5 and have a question concerning the coordinates. How do I rotate the working plane so that an imported drawing appears vertical/horizontal rather than all twisted and crocked. Obviously using the rotate tool is not an option since that would make it impossible to export something back to for example the architect. Just can?t find the right way.. Please help? / Anders Mac OSX Imac 24" Quote Link to comment
islandmon Posted April 26, 2007 Share Posted April 26, 2007 Layer Link the original then rotate then > Edit>Unlock> then > Rotate. This way you can work on the original DesignLayer(s) and see the results in the Linked Layer(s) Quote Link to comment
Christiaan Posted April 26, 2007 Share Posted April 26, 2007 Also see: http://techboard.nemetschek.net/ubbthreads/showflat.php?Number=66931#Post66931 Quote Link to comment
radgivaren Posted April 26, 2007 Author Share Posted April 26, 2007 Ok, thanx for quick answers. I realize now that I not alone in this mess. Let?s just hope they deliver soon. Thanx again! Quote Link to comment
Marietta Posted April 28, 2007 Share Posted April 28, 2007 I have just started trying layer linking to rotate bases from autocad so that I can work on an easier rotation for labelling, etc. What happens when I have to send drawings to Autocad? Will everything go back to the original rotation? What about labelled objects, such as plant tags? These do not like to be rotated - they go back to horizontal and you can't label them in a viewport (not as I understand as part of the Landmark program). I'm also hoping this will come out shortly. Quote Link to comment
ErichR Posted April 29, 2007 Share Posted April 29, 2007 Could it be simply a matter of setting the view to top/plan? Quote Link to comment
