Gary Schryer Posted March 13, 2007 Share Posted March 13, 2007 When I insert doors and assign values in the door settings dialogue box under the data tab, they do not appear on the door schedule, how do I fix this? The only value that does appear is Notes, but it is placed under the comments column of the schedule. Quote Link to comment
Robert Anderson Posted March 13, 2007 Share Posted March 13, 2007 You are using standard Vectorworks door object? The information in the standard vectorworks door schedule comes from the "info" tab of the Door Options dialog. Quote Link to comment
Gary Schryer Posted March 13, 2007 Author Share Posted March 13, 2007 The issue is when you enter materials in the data tab of the door settings dialogue, they do not appear on the schedule, I have entered that I want a HM frame, but it does not appear on the schedule. I am using a mac, os10.4.8 if it makes any difference... Quote Link to comment
Travis Posted March 13, 2007 Share Posted March 13, 2007 Gary, Make sure your schedule has a column for the info you want retrieved. If the door appears on the schedule, all the info is available for that door. . .you just might need to tweak your column headers. Good luck, Quote Link to comment
TBrown Posted March 13, 2007 Share Posted March 13, 2007 I am experiencing the same problem. I have placed several doors into my plan and am now going back and filling in entries within the "Door Settings" dialogue, that I want covered in the "Door Schedule" worksheet. There are certain items I want shown and others I don't. For example I want to display door material and finish, but not rough opening sizes. There are others but these are examples. How do I edit the worksheet columns to have the schedule appear the way I want. It was fairly simple in V11. Quote Link to comment
Travis Posted March 13, 2007 Share Posted March 13, 2007 Sometimes the easiest way to edit a worksheet is to create a new one with the Create Reports option. I (too often) can't remember the "code" for a data item to start a new header. . .so I'll just generate a new report. Yes, you have to recreate the formatting, etc. So it's not always the quickest. Good luck, Quote Link to comment
TBrown Posted March 14, 2007 Share Posted March 14, 2007 It's frustrating that the worksheet generated by selecting "Create VA Schedule" is not easily editable to have the information you want displayed and the information you don't. It was a fairly simple excercise is V11. Is anyone else out there experiencing this problem???? Quote Link to comment
