GW Rodriguez
Moving in 3d - help!
so i have this v10.5 drawing of my theatre that i imported into v12.5 and when i use the flyover tool it only affects the layer i am in. also when i render it only renders in the layer i am in. what am i missing?
i checked the vectorworks help and that command is only for Architect and i have spotlight with renderworks. there is a command in view>align layer views which i have to press every time i make a 3d ajustment but it doesn't work in rendering. any other clues?
Create a model on a separate layer. Insert Layer Links to all the appropriate layers and set your lighting. This is the way of gathering together all your building elements to look at it in any 3d view you want.
