vectorworks to sketchup
RenderWorks does not work for you? Not that I'd be exactly familiar RW. I used to do these in Artlantis beacuse VW & RW didn't deliver. Obviously this "artistic" (deleted.to.avoid.the.wrath.of.moral.rearmament.but.hallelujah.to.you.sister.anyway.pity.about.freedom.of.expression)
has been the focus, so that we could get really tasteless, unartistic and useless renderings done.
You can export a model in VW to use with google early. The Export KML option allows this.
You can also add the other models using a massing model, then do the shadow study.
All right from within VW.
If you really want to use SketchUp, exporting to a DWG is the only option. It's likely the info will be limited when importing the DWG into SketchUp.
We have limited experience bringing VW models into Sketchup 5 on a Mac.
What has worked for us is to Export the model to DWG in Vectorworks 11.5.
We choose DWG V. 2000 for the export. Be sure the model is in top view when you export it.
In SketchUp we open a new file and choose Import, and set the Format to AutoCAD(*.dwg*.dwf). Next to the Format pulldown, we click the "Options" button and check the boxes for " Merge coplaner faces" and "Orient faces consistently". Navigate to the DWG file and click "Import".
If your SketchUp file is defaulted to plan view, the model should come in to SketchUp right on axis.
We have not tried this yet in VW 12.5 or SketchUp 6.
Good luck.
  • 2 weeks later...
