smithar Posted December 24, 2006 Share Posted December 24, 2006 (edited) I am having trouble getting a texture to stay on a base cabinet I got from the object library. The texture would not apply yesterday, however, today when I turned it on and rendered, the objects had the texture I tried to apply yesterday. Then I went to change some properties in the object info pallet and the texture disappeared. Basically if I make any changes to the cabinets they revert to the off white color a rendered object with no texture has. If anyone has any suggestions I would really appreciate your help! I am using vw 12.0 for mac. Edited December 24, 2006 by smithar Quote Link to comment
Damon Design Posted December 31, 2006 Share Posted December 31, 2006 This might be obvious but are you applying the textures by class attributes? Sometimes the textures will "take" better this way. Regardless, I have had issues with some parameters/textures reverting to previous settings when editing other nonrelated parameters in the OIP. Sometimes you just gotta do it again. Good Luck Quote Link to comment
