sfatelier Posted October 23, 2006 Share Posted October 23, 2006 I have outlined an area using poly lines and straight lines. I would like to extrude this. I tried grouping and trying to convert to a polygon but no luck. Is there a way to combine these elements and group them to extrude? Thank you! Quote Link to comment
Guest Posted October 23, 2006 Share Posted October 23, 2006 Modify Compose or Modify Combine Into Surface Quote Link to comment
panthony Posted October 23, 2006 Share Posted October 23, 2006 Use the paint bucket under the polyline tool and fill the area withing your lines. Once that is done you will have a complete closed poly with which to extruede into a 3D object. Pete A. Quote Link to comment
VASTU Posted October 24, 2006 Share Posted October 24, 2006 When rendering a complex building in 3D, in some parts of the building many black artefacts appear. We changed to different angles and modes, but they are always there. Any idea..? Quote Link to comment
Guest Posted October 24, 2006 Share Posted October 24, 2006 VASTU- what version of VW and OS are you using? Quote Link to comment
sfatelier Posted October 24, 2006 Author Share Posted October 24, 2006 I tried that but the "add surface" option was not available. It was greyed out. Any other suggestions? Thanks! Quote Link to comment
panthony Posted October 25, 2006 Share Posted October 25, 2006 sfatelier, You will not be able to create an add surface or combine surface with all of your objects grouped together. You must have each object seperate then you can select them all and use the add surface or use the combine into surface which will give you a paint bucket were you can fill the individual areas created from lines and arcs inta a solid surface which will then be able to extrude into a 3D solid. See below With this example I placed the angled rectangl, oval and circle over the large rectangle then used clip surface to create the seperate objects....selected them all and extruded. Pete A. Quote Link to comment
