Andrew Mac Posted October 3, 2006 Share Posted October 3, 2006 Has anyone ever used the framing tool in architect 11.5? If so, how well does it work? Are the work sheets accurate or does it require a lot of extra work to correct? Quote Link to comment
Travis Posted October 3, 2006 Share Posted October 3, 2006 We use the framing tool extensively, for both roofs and walls. The worksheets are reasonably accurate. . .I might use them to prepare an estimate, but certainly not as a bill of materials. You'll spend a fair amount of time correcting the 3D framed walls, if you choose to use them. The tool is somewhat improved in v12. . .if you don't count the unreliability introduced into the roof framing tool Good luck, Quote Link to comment
