chstech Posted September 26, 2006 Share Posted September 26, 2006 Is there a way to select a few of the viewports and Re-Name them at the same time? Just received a drawing from a client and I want to take "Viewport" 1 ? 10 and make them "Client View" 1 ? 10. Thanks in advance. Quote Link to comment
islandmon Posted September 26, 2006 Share Posted September 26, 2006 Sure is ... goto OIP>Data>Name Quote Link to comment
chstech Posted September 26, 2006 Author Share Posted September 26, 2006 But i am wanting to do it while selecting more than one, Sequentially. I know it can be done one at a time, i just have 2 drawings and about 22 Viewports to re-name. Thanks Quote Link to comment
Jonathan Pickup Posted September 26, 2006 Share Posted September 26, 2006 use the Organization Palette to change the viewport names. You don?t have to select the viewports and you can use cut and paste to edit the names. You still have to use on Object Info Palette like Properties palette, but at least they are all there... if you knew how to make a script you could write a script that would change the names for you... Quote Link to comment
chstech Posted September 27, 2006 Author Share Posted September 27, 2006 Thanks... That is what i thought, but i figured i would ask. Quote Link to comment
