The "eye dropper tool" is a potentialy very useful tool, however clicking on items 1 at a time is very time consuming. Could you give it the same selection options as the "2D selection tool". I.E. rectangular and lasso selection method. Thus allowing multiple objects to be altered at the same time. Would save a lot of time.
The "trim tool" would also benfit from being able to use the lasso selection method triming multiple lines at once.
The "connect/combine tool" is another item which could be greatly improved with the ability to use the lasso tool to first select the items to extend, and then selecting the line to use as a barrier when working in the "single object connect" mode. Probably wouldn't work so well in the "dual object connect/combine" modes.
azizg
6 answers to this question
