gScott Posted June 29, 2006 Share Posted June 29, 2006 currently wall components can be used to close the cavity<s> on window + door PIO's. can this functionality not be extended to any object inserted into walls? this is pertinent to me where custom window or door symbols are used. regards gideon scott Quote Link to comment
0 Christiaan Posted June 29, 2006 Share Posted June 29, 2006 currently wall components can be used to close the cavity How do you do that? Quote Link to comment
0 gScott Posted June 30, 2006 Author Share Posted June 30, 2006 insert a VWA window or door into a wall with 3 components, with the middle component representing the cavity. select the door/window + in the obeject info palette set the Interior Comps + Exterior Comps to "1". as you add the 1's you will see more handles appearing to the side of the door/window. drag those handles around + you will see how you can change the reveals. if you drag each handle to the middle of the outer edge of the jamb you will get a closed cavity... very nice feature... but it would be better if you could apply it to custom symbols inserted into walls too... Quote Link to comment
0 Christiaan Posted June 30, 2006 Share Posted June 30, 2006 Aha, great, thanks Gideon! It took a bit to decipher so here're some further instructions for anyone interested: Insert a plugin door/window into a wall with 3 components, with the middle component representing the cavity. Select the window and click on Settings in the Object Info palette. Go to the Wall Detail tab and add "1" to Number of Components for both Interior and Exterior. Having done this you can now drag the additional handles to each side of your window?doing so parallel to the jamb?to create the cavity closer. Nice feature indeed. Quote Link to comment
0 Christiaan Posted July 14, 2006 Share Posted July 14, 2006 Of course the downside is that this is not the way we typically close cavities these days. Instead we use insulated cavity closers. It would be great if we could insert individual components into walls or something. Quote Link to comment
gScott
regards
gideon scott
4 answers to this question
