michael john williams Posted June 26, 2006 Share Posted June 26, 2006 Create roof is a good basic tool but it is very basic. Why can not the same roof have different eaves heights? Would it not be great if you had two roofs and you could join them like two walls, say an annexe roof to the main roof? Quote Link to comment
0 Jonathan Pickup Posted June 26, 2006 Share Posted June 26, 2006 you can have different eaves heights on each roof plane Quote Link to comment
0 michael john williams Posted June 27, 2006 Author Share Posted June 27, 2006 Jon Thanks, you are right, but you can not join 2 roofs and I know you can set the roof up with different planes rather than use the simple roof tool, but that is a bit complicated and we are working through this one now in your manual. Its just I wish the roof tool did more and did not just give up and say 'roof too complicated'. Another thing I feel could be improved with roofs is the fit walls to roof tool - gosh it takes a long time to regenerate and sometimes you are not sure what it is doing or whether it has crashed. Then the result can be poor, the walls do not embed themselves in the roof completely with gaps or too high - wide walls and steep roofs are a nightmare. Also gable walls sometimes stop short of the roof and we have identified this as a problem of the corner junction of the walls and it is best not to join the walls but to have them abutt each other but this leaves alin in elevation. Quote Link to comment
0 Jonathan Pickup Posted June 27, 2006 Share Posted June 27, 2006 for fit walls to roof, make sure the roof is in a separate layer, preferably on it?s own Quote Link to comment
0 michael john williams Posted June 28, 2006 Author Share Posted June 28, 2006 It is!? Quote Link to comment
4 answers to this question
