Cbeckwith Posted June 15, 2006 Share Posted June 15, 2006 My drawing is right in the middle of my print grid, set for 11 x 17, ASME B for drawing and Printer Setup. Scale size is 1:240 and the Origin is set in the middle of the drawing. The problem is when it goes to the printer, the print looks like one quarter of the drawing, Top Left Quadrant is printing out. Don't know what else to do. Quote Link to comment
cbaarch Posted June 15, 2006 Share Posted June 15, 2006 what version of VW - MAc or Win what printer are you using what is the setup of the printer are you using Viewports and Sheets? what are the sequence of events that you doing to Print Quote Link to comment
Cbeckwith Posted June 15, 2006 Author Share Posted June 15, 2006 what version of VW - MAc or Win what printer are you using what is the setup of the printer are you using Viewports and Sheets? what are the sequence of events that you doing to Print I am using Version 12, with a HP2500C model printer, good for 11 x 17 prints. It is set for Tabloid, tray 1 where the 11 x 17 paper is and in Landscape mode. I am using sheets not Viewpoints...... Quote Link to comment
Guest Posted June 15, 2006 Share Posted June 15, 2006 What OS are you using? It sounds like the page size is set to something other than One Page in the Page Setup dialog box. Quote Link to comment
Cbeckwith Posted June 19, 2006 Author Share Posted June 19, 2006 It is set for ASME B - 11 x 17" Prints. Can I send this file to you for you to try? It is 342K What OS are you using? It sounds like the page size is set to something other than One Page in the Page Setup dialog box. Quote Link to comment
Kevin Posted June 19, 2006 Share Posted June 19, 2006 Katie is referring to the Page Setup dialog that shows pages vertical and horizontal. It should read 1 page vertical and 1 page horizontal. Quote Link to comment
Cbeckwith Posted June 20, 2006 Author Share Posted June 20, 2006 I checked the Page Setup. It says 2 for Horizontal and 2 for Vertical. When I select one page or other, it shows for Letter, then when I physically change the Width and Height, it changes back to 2 pages for both. Same happens when I select ASME B. Quote Link to comment
Travis Posted June 20, 2006 Share Posted June 20, 2006 It would help a great deal to know which OS you're using. Quote Link to comment
Cbeckwith Posted June 20, 2006 Author Share Posted June 20, 2006 Version 12, I think I have resolved the problem on the Page Setup. Thanks for your input. Quote Link to comment
Guest Posted June 20, 2006 Share Posted June 20, 2006 This page size should be set to One Page or one horizontal/vertical if you want it to print directly to the printer. Quote Link to comment
