jnr Posted June 12, 2006 Share Posted June 12, 2006 So what happened to text fill on the drawing labet PIO? Select a background fill and it only fills the circle. Un check no fill behind text in preferences, and still the text in the pio does not fill behind it. Did not happen in 11. Any ideas? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted June 13, 2006 Vectorworks, Inc Employee Share Posted June 13, 2006 I believe this is on purpose. Obviously, the text in this PIO has to be drawn later than the background bubble. If the text is filled, it can block out portions of the bubble. For that reason it is mandated to have no fill. Is this causing a problem? Quote Link to comment
jnr Posted June 19, 2006 Author Share Posted June 19, 2006 Yes. I'm referring to the the text in the title and scale, not the reference #'s inside the bubble. On various occasions I've had to put a reference in front of a viewport and the text gets lost or is hard to read. One is left to inserting filled rectangles behind the label PIO, which is a pain and should be unnecessary. Text used to fill in the titles and worked just fine in 11 if memory serves me. Quote Link to comment
