Bruce Kieffer Posted May 26, 2006 Share Posted May 26, 2006 Are there any garage doors in any of the VW libraries? If so, which library? Thanks. Quote Link to comment
dunsterville Posted May 27, 2006 Share Posted May 27, 2006 Hello, try navigating . . . Applications > VW > Library > Objects-Metric > 31.5_Doors_Overhead.mcd Quote Link to comment
Guest Posted May 27, 2006 Share Posted May 27, 2006 The door tool has an overhead door configuration, which is the same as a garage door. Quote Link to comment
Bruce Kieffer Posted May 27, 2006 Author Share Posted May 27, 2006 Hello, try navigating . . . Applications > VW > Library > Objects-Metric > 31.5_Doors_Overhead.mcd dunsterville, I don't seem to have that library. Thanks. Quote Link to comment
Bruce Kieffer Posted May 27, 2006 Author Share Posted May 27, 2006 The door tool has an overhead door configuration, which is the same as a garage door. Katie, I don't have a door tool. The VW help tells me it's a part of architect, and I have fundamentals. I'm not an architect, I just want to draw my house. Quote Link to comment
Bruce Kieffer Posted May 28, 2006 Author Share Posted May 28, 2006 (edited) I found a VW 11 library called overhead doors that has what I need. dunsterville, it's probably the imperial version of the file you referred to. Thanks to all. Edited May 28, 2006 by Bruce Kieffer Quote Link to comment
gbrooks Posted May 28, 2006 Share Posted May 28, 2006 I have an older version of architect and my pc crashed forcing me to reinstall. I cannot remember how to put my serial number in. During install I was not prompted. Can you help? Quote Link to comment
CipesDesign Posted May 28, 2006 Share Posted May 28, 2006 (edited) gbrooks, firstly your problem has nothing to do with this thread. In the future you should start a new thread if you have a new question. Secondly, as best I can remember, if you weren't prompted during the VW's install you probably will be the first time you run VW's. Just open the app. and see what happens :=0 Edited May 28, 2006 by CipesDesign Quote Link to comment
