Andrew Mac Posted May 11, 2006 Share Posted May 11, 2006 I know this has been discussed but I am trying to create a 3-d model of a 2 story home, 1st floor, 2nd floor, roof- I am using vectorworks Arch. 11.5.2 and am wondering if I can generate a rendered drawing without the lines on the exterior of the home(lines represent the individual floors stacked on one another)I would like just one solid surface for the exterior of the home Quote Link to comment
aron Posted June 5, 2006 Share Posted June 5, 2006 in order make a single surface in vw the surface most be one object. good luck Quote Link to comment
Jonathan Pickup Posted June 5, 2006 Share Posted June 5, 2006 if you assign the same texture to both parts of the building (the upper and lower floors) then you shouldn?t see a join. Final Quality RenderWorks won?t show the lines anyway... if you are using hidden line renderings then there is a way to do this, you need to make a thin 3D shape, a bit like a skirt that goes around the joint in the two walls. The trick is that the skirt has no line on it.. Quote Link to comment
