Thom Posted February 21, 2006 Share Posted February 21, 2006 I would like the ability to assign the text portion of the property line tool a separate class from the acutal lines. When modeling a subdivision, I want the lines but not the text. Quote Link to comment
0 Thom Posted February 21, 2006 Author Share Posted February 21, 2006 Robert Partially, Also when showing several alternatives, the clients seem to relate to the different layouts if the line colors are different, even though they are on different sheets. However, black text always reads the best. Also would make turning text on and off easier and easier to manipulate. Something like the room command tool, I think. Also when evaulating layouts, many times I will have them overlayed without the text on. It would be nice to turn a separate class on to see data for a certain layout without having to isolate the layer, select all, turn on / off "Annotate Segments" to see data, then reverse to clean up the dwg. Quote Link to comment
0 Vectorworks, Inc Employee Robert Anderson Posted February 22, 2006 Vectorworks, Inc Employee Share Posted February 22, 2006 Thom, Why not just turn off the "Annotate segments" property? Is this because you want the text stuff only in certain viewports? Quote Link to comment
0 Itchy Posted September 28, 2023 Share Posted September 28, 2023 Rather old post (17 years) but I would still like this. I want the data shown for some viewports and others just the property line. I tried to see if the data tag could pull the data of each line segment but no luck on that. My workaround is to ungroup the property line, which is fine unless I need to go back and change boundaries (new subdivisions etc) Quote Link to comment
Thom
3 answers to this question
