I've now had VW11 for a week or so. It's good....but could be better...here are some early suggestions to do with viewports and Design/Sheet Layers...
1. A Duplicate function for Sheet Layers. Bizarrely this is not included...so you spend ages setting up your sheet and viewport and page setup...and can't copy it for your next 10 sheets. Doh!
2. Now that we have Sheet Layers with individual page/print setups, the use of page setup on Design Layers will be greatly reduced. Can we have a toggle to turn off the print window outline in Design Layers...it's annoying, always has been.
3. When I switch to a Sheet Layer...why on earth would I want to maintain the zoom/view I was using on a Design Layer? When a sheet layer is made active, the view should zoom to the print window.
The viewport handily saves my class/layer combinations, but I would still need to use the old saved views (was saved sheets) feature to be able to flick though my drawing sheets and see them sat nicely on the screen.
Chris D
Flawed logic NNA.
6 answers to this question
