Jodak Posted April 22 Share Posted April 22 Is there any way to automaticly create a section viewport? It should be possible to copy a section line, but how do i create a section viewport from that? Quote Link to comment
JBenghiat Posted April 24 Share Posted April 24 To create a VP, call CreateVP() and use object variables to set as section: https://developer.vectorworks.net/index.php?title=VS:CreateVP https://developer.vectorworks.net/index.php?title=VS:Function_Reference_Appendix_G#Viewports However, creating a section VP via VS doesn't seem possible // Viewport type selectors // -------------- const short ovViewportProjectionType = 1000; // short read/write - the viewport projection type. - Public for VS const short ovViewportRenderType = 1001; // short read/write - the viewport render type. - Public for VS const short ovViewportPerspectiveDistance = 1002; // real read/write - the viewport perspective distance (used with custom perspective). - Public for VS const short ovViewportScale = 1003; // real read/write - the viewport scale. - Public for VS const short ovViewportDirty = 1004; // Boolean read/write - the viewport out-of-date (dirty) state. - Public for VS const short ovViewportProject2D = 1005; // Boolean read/write - the viewport project 2D state. - Public for VS const short ovViewportRenderBackground = 1006; // Sint32 read/write - the viewport render background. - Public for VS const short ovViewportViewType = 1007; // short read/write - the viewport view type. - Public for VS const short ovViewportLineWeightScale = 1008; // double read/write - the viewport line weight scale. - Public for VS const short ovViewportArrowheadScale = 1009; // double read/write - the viewport arrowhead scale. - Public for VS const short ovViewportDashedLineScale = 1010; // double read/write - the viewport dashed line length/spacing scale. - Public for VS const short ovViewportHatchLineScale = 1011; // double read/write - the viewport hatch line spacing scale. - Public for VS const short ovViewportDesignTextScale = 1012; // double read/write - the viewport design layer referenced text size scale. - Public for VS const short ovViewportSlashThicknessScale = 1013; // double read/write - the viewport slash thcikness scale. - Public for VS const short ovViewportAmbientIsOn = 1014; // Boolean read/write - the viewport ambient light is ON or OFF. - Public for VS const short ovViewportAmbientBrightness = 1015; // double read/write - the viewport ambient light brightness. - Public for VS const short ovViewportAmbientColor = 1016; // WorldPt3 read/write - the viewport ambient light color. - Public for VS const short ovSetDesignLayerVisibilityInAllViewports = 1017; // short, -1 = invisible, 0 = normal, 2 = grayed - Public for VS const short ovSetClassVisibilityInAllViewports = 1018; // short, -1 = invisible, 0 = normal, 2 = grayed - Public for VS const short ovViewportHDRIBackground = 1019; // Sint32 read only - the background for environment lighting - Public for VS const short ovSectionVP2DAttributeClass = 1020; // Sint32 read only - the RefNumber of the class responsible for attributes of overall cross-section or just the x-section of structural elements. - Public for VS const short ovSectionVP2DOtherAttribClass = 1021; // Sint32 read only - the RefNumber of the class responsible for attributes of cross-section generated from non-structural elements - Public for VS const short ovSectionVP3DFillStyleClass = 1022; // Sint32 read only - the RefNumber of the class reposnsible for fill style of the objects beyond section plane - Public for VS const short ovSectionVP3DLineStyleClass = 1023; // Sint32 read only - the RefNumber of the class responsible for line style of the objects beyond section plane - Public for VS const short ovViewportXPosition = 1024; // double read only - the X coordinate of the viewport on the sheet layer - Public for VS const short ovViewportYPosition = 1025; // double read only - the Y coordinate of the viewport on the sheet layer - Public for VS const short ovViewportAngleWithXAxis = 1026; // double read only - the angle that the viewport subtends with the X axis on the sheet layer in degrees - Public for VS const short ovViewportShowWallComponents_OBSOLETE = 1027; const short ovViewportGrayTransparent = 1028; // Boolean read/write - the viewport renders gray layers transparent - Public for VS const short ovViewportFlipText = 1029; // Boolean read/write - the viewport/dlvp adjusts for flipped text - Public for VS const short ovViewportBlackAndWhite = 1030; // Boolean read/write - the viewport/dlvp draws in black and white only - Public for VS const short ovViewportUseDocumentClassVis = 1031; // Boolean read/write - set/reads the Use Document Class visibilities settings for dlvps - Public for VS const short ovViewportDescription = 1032; // TXString read/write - a description for the viewport, which corresponds to the Dwg Title field for a corresponding Drawing Label. - Public for VS const short ovViewportLocator = 1033; // TXString read/write - the locator for the viewport, which corresponds to the Item field for a corresponding Drawing Label. - Public for VS const short ovViewportIsLinked = 1034; // Boolean read - indicates whether the viewport is a linked viewport const short ovViewportDisplayPlanar = 1035; // Boolean read/write - the flag to indicate if planar and 2D objects are to be displayed const short ovViewportForegroundRenderType = 1036; // short read/write - the viewport render type. - Public for VS const short ovViewportHasCamera = 1037; // Boolean read only - whether there is a camera attached to the viewport or not const short ovCameraAttachedToViewport = 1038; // Boolean read only - whether the camera is attached to a viewport or not const short ovViewportCropVisible = 1039; // Boolean read/write - get/set the Crop Visible state of a viewport - Public for VS const short ovViewportLayerHeightIgnored = 1040; // Boolean read only - whether the viewport ignored layer height for single layer case const short ovViewportLightingDevice = 1041; // read/write - make an association between a lighting device light and an overriden light object for the viewport. const short ovViewportRePositionDimensionText = 1042; // Boolean read/write - the viewport/dlvp re-positions dimension text to other side of dimension line - Public for VS const short ovIsDesignLayerSectionViewport = 1043; // Boolean read only - indicates whether the linked viewport is a sheet layer or a design layer viewport - Public fo VS const short ovFDLSVPHiddenLineInWireframe_OBSOLETE = 1044; const short ovViewportPageSymbolScale = 1045; // double read/write - the viewport page symbol scale. - Public for VS const short ovViewportNavigateToFromSectMarker = 1046; // Boolean write only - selects the viewport and makes it visible - Not for public use const short ovViewportDetailLevel = 1047; // short read/write - low detail = 0, medium detail = 1, high detail = 2 - Public for VS const short ovViewportIsHorizontalSection = 1048; // Boolean read - indicates whether the viewport is horizontal section const short ovViewportTransformMatrix = 1049; // TransformMatrix read/write const short ovViewportViewMatrix = 1050; // TransformMatrix read/write const short ovViewportOperatingTransform = 1051; // TransformMatrix read const short ovViewportUnscaledBoundsWithoutAnnotations = 1052; // WorldRect read const short ovViewportResetForOnlyAnnotationsChange = 1053; // void write const short ovIsSectionViewport = 1054; // Boolean read only - indicates whether the viewport is a section viewport - Public for VS const short ovSheetLayerSectionViewportViewMatrix = 1055; // TransformMatrix read const short ovSectionViewportSectionViewMatrix = 1056; // TransformMatrix read/write const short ovViewportAttachDefaultRenderOptions = 1057; // Boolean(ignored) write const short ovViewportAttachDefaultCustomRenderWorksRenderOptions = 1058; // Boolean(ignored) write const short ovViewportDisplay2DComponents = 1059; // Boolean read/write const short ovViewportHiddenLineDisplay2DFills = 1060; // Boolean read/write const short ovViewportAttachDefaultLightingOptions = 1061; // void write const short ovViewportCreateDefaultEditableGroups = 1062; // void write const short ovViewportPrivateLayer = 1063; // MCObjectHandle read const short ovSectionViewportDisplayObjectsBeyondCutPlane = 1064; // Boolean read/write const short ovSectionViewportDisplayObjectsBeforeCutPlane = 1065; // Boolean read/write const short ovViewportHiddenLineDisplay2DFillsAllowed = 1066; // Boolean read const short ovSectionViewportCastShadowsFromRemovedPortion = 1077; // Boolean read/write const short ovSectionViewport2DResultsMerged = 1078; // Boolean read/write const short ovSectionViewport2DAttributesUseClass = 1079; // Boolean read/write - must be set true before you set class with ovSectionViewport2DAttributesClass const short ovSectionViewport2DAttributesClass = 1080; // RefNumber read/write const short ovSectionViewport2DOtherAttribsUseClass = 1081; // Boolean read/write - must be set true before you set class with ovSectionViewport2DOtherAttribsClass const short ovSectionViewport2DOtherAttribsClass = 1082; // RefNumber read/write Quote Link to comment
Jodak Posted Sunday at 07:24 AM Author Share Posted Sunday at 07:24 AM Thats sad. Any chances to change the linked viewport of a section viewport? Like making changes on the database? I could not find any databases linked to a sectionviewport?! Quote Link to comment
