Symbols renders are too thick and dont show properly
rajai
Hello ,
On VW24 , when publishing to PDF , suddenly im getting very thick lines on the symbols (lighting and others) , while text , and other CAD import lines are fine
Sheet layer is at 300 DP, detail level at high , export is at lossless
any ideas ?
1 answer to this question
This is probably a scale issue. If you activate Zoom Line Thickness from Vectorworks preferences or from the button in the Quick Preferences bar (you may have to enable it there), you will probably see the result you see in the final PDF.
The solution is to change your design Layer scales or your pen thicknesses. However, that is something you should do early on in the process. If you are too far down the road and have laid out your viewports already, you can scale the pen thicknesses in the viewports by selecting the Advanced button and scaling them there.
Come back if you need more info.
