Ryoung Posted March 14 Share Posted March 14 I'm trying to use the typical symbol in an equipment summary key VW2024 Update 4. There appears to be some issues getting the symbol to display properly. I'f I select the default label legged for the typical symbol (As I would have done in the past) All I get are the labels themselves, so default fixture body and no containers. I can select the fixture body instead of the default label legend, and I see that, but then no labels. and still no containers. It almost seems as if I need a way to show certain classes in the Equipment Summary Key. Is this a known bug, or is there something that I'm missing? Thanks! 06 Reports.vwx Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted March 14 Vectorworks, Inc Employee Share Posted March 14 Hi Ryan, You've found a bug. The file looks like it was originally from an older version of VW. I'm not sure if that's the issue. But it should still work, no doubt. I tend to use an actual symbol instead of the label legend, which is currently working. Here's a video. Best, Scott TypSymbol.mp4 Quote Link to comment
Ryoung Posted March 14 Author Share Posted March 14 Thanks so much I appreciate the workaround. 1 Quote Link to comment
