Stefan B. Posted March 13 Share Posted March 13 I'm constantly making new trusses to our library and is making them as trusses in VW. This for the most goes like a charm, but VW has some hick-ups here and there, that makes VW crash. I cannot at this point pinpoint what is causing the crash and this is not the core of the question. If the truss is only placed in the Resource manager, and it has a error with some of the properties in the Truss properties, how do you access this dialog box? Since drawing the truss in a drawing makes VW crash, and this menu is not accessible from the resource manager. Quote Link to comment
Scott Campbell Posted March 13 Share Posted March 13 Right click on the Truss symbol in the Resource Manager and select "Attach Record…". Highlight the Record you wish to edit, then click the "Edit values…" button. Be aware that the edited record values will not be updated in any truss instances previously created in the model. Quote Link to comment
Stefan B. Posted March 13 Author Share Posted March 13 47 minutes ago, Scott Campbell said: Right click on the Truss symbol in the Resource Manager and select "Attach Record…". Highlight the Record you wish to edit, then click the "Edit values…" button. Be aware that the edited record values will not be updated in any truss instances previously created in the model. No, not the record, the Truss properties that gets enabled after you attach the truss record. Quote Link to comment
Scott Campbell Posted March 13 Share Posted March 13 Thanks for the clarification. As far as I know, the "Truss Properties" dialog can only be accessed via an instance in model (right-click on truss instance and chose from context menu). So, that brings us back to start: Vectorworks crashes when attempting to place an instance of a Truss object in the model. I think we need to troubleshoot based on the crash, and now it seems necessary to ask you to share a file with the Truss culprit, if you can, for testing. Thanks. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted March 14 Vectorworks, Inc Employee Share Posted March 14 On 3/13/2024 at 6:26 AM, Stefan B. said: Since drawing the truss in a drawing makes VW crash, We likely want a copy of this file. Having files we know will crash when repeating the same steps is gold for the programmers. Can you share? Quote Link to comment
Stefan B. Posted March 19 Author Share Posted March 19 On 3/14/2024 at 10:25 PM, Scott C. Parker said: We likely want a copy of this file. Having files we know will crash when repeating the same steps is gold for the programmers. Can you share? Sure, I'll make a new file and make sure it crashes. 🙂 Give me some time and I'll reply with a file. 🙂 1 1 Quote Link to comment
Stefan B. Posted March 26 Author Share Posted March 26 So, i gave this a try, and could not replicate the fault. In my original attempt I made 4 custom truss symbols, and got the crash 3 out of 4 times. So was pretty sure i cold replicate it. I'm waiting to draw two or three more circle truss, when i get the data, i send a file over if VW decides to crash then. Quote Link to comment
