Convert REAL to inches in Vectorscript
I am writing a small script to create Shell Solid for a selected object. The current Document Settings units is in decimal inch.
In the below script, I want to create a shell solid at 2" thickness. However, after running the script, the shell object thickness is at .079". Is there a way to convert REAL number to the correct unit in inches?
h = vs.FSActLayer()
vs.CreateShell(h, 2)
Thanks
Just flagging that this is in the VectorScript forum, but your code is in Python. This is one of the few things that VS does more easily: you can just specify units, i.e. CreateShell(h, 2”).
In Python you have to do unit conversions. vs.ValidNumStr is the most robust
https://developer.vectorworks.net/index.php?title=VS:ValidNumStr
Just to throw a wrench in things, I believe some functions always take millimeters, and this may be one of them. Best practice there is to retrieve the units per inch preference, and convert input numbers into millimeters.
