builtextra007 Posted January 25, 2024 Share Posted January 25, 2024 i have an existng wall and a proposed wall for a garage i want to add the garage door between the existing and new portion to center it if i extend the existing wall , then the existing floor plan on the construction docs wouldnt look right how do i put the door in the center of two wall types? Quote Link to comment
mike m oz Posted January 26, 2024 Share Posted January 26, 2024 Doors can't extend past the end of a wall so you will have to create Openings with the Door Tool in the separate walls and then manually place the door into the opening created. Make sure the Wall Insertion Mode is off when you do that to prevent it inserting it into one of the walls. It might also be prudent to give it a unique Class and temporarily switch the Class Options to Show/Snap Others. Quote Link to comment
builtextra007 Posted January 27, 2024 Author Share Posted January 27, 2024 thank you! Quote Link to comment
