tspilman Posted January 25, 2024 Share Posted January 25, 2024 Hi all, How do I get 'compare to inventory' to work in 2024? I have created added a venue's equipment list to the inventory and equipment list, and I have correctly set up the source in symbols and parts (In use and remaining counts appear to be correct). However, when I create an equipment summary, and select 'compare to inventory' I just get #/0 for each line item. I cannot work out what I am doing wrong. Any suggestions? TIA Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted January 25, 2024 Vectorworks, Inc Employee Share Posted January 25, 2024 2 hours ago, tspilman said: 'compare to inventory' I just get #/0 for each line item. Hi Tim, I'm sorry to say we're hunting some bugs and an implementation issue. Both are being worked on. The implementation issue is a system limitation that currently restricts the comparison to inventory to work with used plug-in symbols only and not the regularly used equipment symbols we are used to using. Fixing this is a longer process than anyone wishes. To have your counts work, please insert the plug-in version of the symbols, and then the counts should work. I just found a new bug when I made the above screenshot. If you assign items to inventory sources, the compared quantities (10 in this example) revert to zeros. I'm reporting that now. Quote Link to comment
jkirchhofer Posted March 26, 2024 Share Posted March 26, 2024 Switching to using the plug in objects only partially solves the compare to inventory problem. There is a fundamental flaw if you are using accesories, in that each combination generates another plug in object with the accessory associated, so short of having 4 entries for a Source 4 Par (one plain, one with barndoor, one with sidearm, and one with sidearm+barndoor) which then requires adding the quantities of those variations manually to compare to inventory, as well as being an entirely cumbersome key. There is also no way to use plug in objects for accessories as they do not appear by themselves in the plug in objects list (they appear as sub-parts of the units they are attached to, and you cannot add anything but the entire unit to the display list.) Quote Link to comment
jkirchhofer Posted March 26, 2024 Share Posted March 26, 2024 (edited) I did some more work in a test file and while I wasn't able to find any workaround, I did at least generate a clear demonstration of the extent of the problem and how broken the current option is. The entirety of the 'plot' is in the lower right with two versions of the key, neither of which is particularly successful. I also noticed there was no way to include an instrument that doesn't exist in the plot (but does exist in the inventory) in the key and include the count available, as even if you plot a dummy instrument to force the object to show up in 'Used Plug In Objects' if you then delete the dummy object to make the counts correct, it then disappears from the key as well. Edited March 26, 2024 by jkirchhofer Formatting Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted April 8, 2024 Vectorworks, Inc Employee Share Posted April 8, 2024 @jkirchhofer Thanks for looking into this. We are working on solutions, but the timeline will likely not make either of us happy in the short term. Quote Link to comment
JYT Posted June 6, 2024 Share Posted June 6, 2024 Hello, Just Updated to version 5 and I didn't notice any changes to In Use units vs Counts available. I am still unable to get proper accounting of gear via Equipment Summary. Cheers, JYTessier VW2024 Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted June 7, 2024 Vectorworks, Inc Employee Share Posted June 7, 2024 On 3/26/2024 at 4:37 PM, jkirchhofer said: no way to include an instrument that doesn't exist in the plot (but does exist in the inventory) The key was never designed to show items not shown in the drawing. The key only looks at items included in the drawing and displays what it finds. To report on your inventory stock, you need to open the file from which the inventories were created and build reports. On 6/6/2024 at 8:57 AM, JYT said: version 5 and I didn't notice any changes to In Use units vs Counts available. Using the symbols in the key is still not an option. It likely won't be for the remainder of the 2024 cycle, and it's doubtful it'll be in the first rounds of 2025, either. We have added a new reporting function in 2025 that will report quantities of gear and show the remaining available gear in used inventories. Placing this report along side the key will be very helpful. Quote Link to comment
Simon Farrow Posted May 20, 2025 Share Posted May 20, 2025 The old "Instrument Summary Tool" and the "Lighting Inventory Setup" menu option can both be located in the workspace editor. The "Instrument Summary Tool" is found in Tools>Legacy, and the "Lighting Inventory Setup" is found in Menu>Legacy in the workspace editor. Add them both back into your workspace and keep going like its 2023. I sincerely hope that Vectorworks will not remove these options until they fix the major dysfunctional issues with the new "Equipment Summary Key Tool". Quote Link to comment
