Sky Posted January 8 Share Posted January 8 I'm putting a new wall in front of an existing window with an arched opening. When the window configuration is "Opening" or "Cased Opening", it doesn't show the opening. If I set it for any other configuration, it is visible. Is there a setting to make an "Opening" show in the wall in 2D? Quote Link to comment
Sky Posted January 8 Author Share Posted January 8 Nevermind - I figured it out. I was duplicating a window that was created in VW2023 before I imported this project into VW 2024. I had to create a completely new window in VW2024 to get it to display properly. Quote Link to comment
Jonathan Pickup Posted January 8 Share Posted January 8 9 minutes ago, Sky said: Nevermind - I figured it out. I was duplicating a window that was created in VW2023 before I imported this project into VW 2024. I had to create a completely new window in VW2024 to get it to display properly. it looked to me like you have two different windows selected in each image. Quote Link to comment
Sky Posted January 8 Author Share Posted January 8 I think I had my cursor hovering on the existing window, but you can see the blue handles for the selected window. The Object Info also clearly shows Configuration: Opening. I worked with that windows for 10 minutes trying to get it to display so it definitely isn't a selection issue. 1 Quote Link to comment
