Mike Wood Posted January 7 Share Posted January 7 Hello! I'm trying to add a field to a data tag that I use for lighting position labels to represent the total instrument count of instruments that are attached to said position. ' I feel like this **should** be able to happen using this Sum Insts parameter but when I do that, it displays the data as a boolean instead of an integer. Sure I'm missing something simple but I can't figure it out. Thanks! Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 8 Vectorworks, Inc Employee Share Posted January 8 The hanging position does not contain this data, so it can not be displayed in a data tag. When the position summary option is checked on the hanging position an equipment summary key object is created to display the data. Quote Link to comment
Mike Wood Posted January 8 Author Share Posted January 8 (edited) What is the Sum Insts - #Sum Insts# parameter actually for, then? Edited January 8 by Mike Wood Quote Link to comment
Mike Wood Posted January 8 Author Share Posted January 8 Ohhh, Is "sum" in this instance just short for Summary? That's a bit confusing, I'd expect it to be an actual Sum. I think I follow now. Bummer! Quote Link to comment
