Jiajing Posted January 6 Share Posted January 6 Need help on COMPARE TO INVENTORY of Equipment Summary. For instance, I have (1) leko with total inventory of (10). When I turn on COMPARE TO INVENTORY on Key, it shows inventory as (0). My question is: * which inventory is key referencing to Am i missing anything here Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted January 7 Vectorworks, Inc Employee Share Posted January 7 It should compare to all inventories with a check in the use column. However, the comparison is looking at the plug-in version of the symbols vs. the symbol version at the moment. Quote Link to comment
Jiajing Posted January 8 Author Share Posted January 8 23 hours ago, Scott C. Parker said: It should compare to all inventories with a check in the use column. However, the comparison is looking at the plug-in version of the symbols vs. the symbol version at the moment. Thanks, Scott. Changed to plug -in version of the symbol, it looks same to me. Quote Link to comment
JBoshler Posted January 8 Share Posted January 8 If you go to Spotlight > Reports > Lighting Inventory Setup, you can set up your allocation there. By default, the values are zero. Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted January 8 Vectorworks, Inc Employee Share Posted January 8 12 hours ago, Jiajing said: Changed to plug -in version of the symbol, it looks same to me. Can you share a sample file to test? Quote Link to comment
Jiajing Posted January 8 Author Share Posted January 8 @Scott C. Parker Attached. Inventory.vwx Shop1.xml Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted January 8 Vectorworks, Inc Employee Share Posted January 8 37 minutes ago, Jiajing said: Attached THanks. It's a bug. I'll put in a report. Quote Link to comment
Jiajing Posted January 8 Author Share Posted January 8 2 hours ago, Scott C. Parker said: THanks. It's a bug. I'll put in a report. Thank you, Scott. Also would love to the difference between plug in of symbol VS. Symbol itself. Would it be great that just show light devise as ome kind if possible Quote Link to comment
