JBoshler
    4
Reputation
1 Neutral
Personal Information
  • Location
    Australia
  1. Hi Scott, As schematics weren't able to copy over to a new file, I drew a fresh file from scratch, attached. The same issues occurred in a blank file, as shown on the unit channeled 2. I also included a different bug in where if you over-rig a fixture, the schematic can't line up the channel number and container. In this symbol in particular, it also appears to mess up the symbol within a symbol and split some line work in the plan view. Schematic Test Bug.vwx
  2. If you go to Spotlight > Reports > Lighting Inventory Setup, you can set up your allocation there. By default, the values are zero.
  3. Hi, I appear to be having a similar issue in 2024 update 2, where I seem to be losing the key lines that differentiate beam angles as per the attached screenshot (81+82 are 26deg, 83+84 are 19deg). I've reset plugins as mentioned above.
  4. - As selecting a circuit sets priority for HopOver, being able to hold Alt to select a circuit (similar to other tools such as Offset). - Be able to "flip" the orientation of the curve to the other side of the hopped cable (from below to above, or from left side to right side).
