Bruce Kieffer Posted January 2 Share Posted January 2 Layers and sheets default sort by stacking #. Is there a way to change the default to alphabetical? I change it manually when I boot Vectorworks, but Vectorworks reverts every time I quit and restart Vectorworks. Quote Link to comment
rDesign Posted January 2 Share Posted January 2 Cllick and drag the Layers to change their stacking order. Then they will stay in the correct stacking order upon reopening the file. Quote Link to comment
Bruce Kieffer Posted January 2 Author Share Posted January 2 1 minute ago, rDesign said: Cllick and drag the Layers to change their stacking order. Then they will stay in the correct stacking order upon reopening the file. That will work, but that is not changing the default sort, which is what I want. 1 Quote Link to comment
rDesign Posted January 2 Share Posted January 2 (edited) It is not currently possible to change the default Layer sorting to alphabetical; you should create a wish list item for this if you see a need for it. Edited January 2 by rDesign 1 Quote Link to comment
