Isaac Anderson Posted December 21, 2023 Share Posted December 21, 2023 Hi All, I am working on a project where I need to measure multiple lines drawn on top of an object and combine their distance to one measurement (IE 5x 10' sections of LED tape, adding to a total of 50'). I started using data tags to visualize the length of the individual sections, but am unable to find a way to automatically add all of these sections together. Is it possible for a single data tag to be applied to (& add) multiple objects to get it's final value? Thank you, Quote Link to comment
Pat Stanford Posted December 21, 2023 Share Posted December 21, 2023 Data tags are intended to return data on the individual tagged object only. You are going to have a very difficult (read impossible) time trying to get a data tag to report on multiple objects. The only possible solution I could see would be a data tag that is not associated with the objects but that uses some other critters (maybe class or a record attached to the objects) to get the sum. But in 10 minute of playing I could not get that to work. Quote Link to comment
Isaac Anderson Posted December 21, 2023 Author Share Posted December 21, 2023 1 hour ago, Pat Stanford said: Data tags are intended to return data on the individual tagged object only. You are going to have a very difficult (read impossible) time trying to get a data tag to report on multiple objects. The only possible solution I could see would be a data tag that is not associated with the objects but that uses some other critters (maybe class or a record attached to the objects) to get the sum. But in 10 minute of playing I could not get that to work. Thanks, Pat. I had a similar result yesterday and today. Alas, we all must do things manually from time to time. Cheers Quote Link to comment
