bob cleaver Posted December 18, 2023 Share Posted December 18, 2023 I am learning the best way to use the lidar function and the nomad app: I recently bought an iPhone 15 pro and used the lidar scan feature in the nomad app to produce the 2 scans in the file attached. The enclosed file has 2 scans performed on the same day. The 2 scans are adjacent areas and there is an issue with vertical and horizontal alignments. This forum is the best solution for recommendations and I appreciate any recommendations for best practices. VW forum 3D scans bob cleaver.vwx Quote Link to comment
zoomer Posted January 1 Share Posted January 1 I have only scanned a single Point Cloud of a room so far. AFAIK working with even single point clouds or photogrammetry in VW always meant - scaling - rotating - aligning - cropping When I stopped scanning I got a warning that I will no more be able to continue scanning. Which I didn't want, but I also expected that Nomad that way would do some magic to keep location of the scans synchronous. But how could you realistically align PCs or find a special point to align both PC ? As soon as I zoom in a bit I lose overview. What do you expect to do with the PC, or better how do you create VW geometry from it, by creating a DTM from it ? 1 Quote Link to comment
bob cleaver Posted January 1 Author Share Posted January 1 (edited) Vectorwork’s Tony K has a webinar where he combined 3 separate PCs into one site plan. The goal of mine is to create a site plan in 2D and then a 3D model. Tony’s webinar is excellent in working through the steps, but his PCs did not have the same distortion I have. Edited January 1 by bob cleaver Fill in additional info 1 Quote Link to comment
