Grey Class Visibility
Jim Smith
I have a work-a-round but wonder if newer versions of VW have fixed this issue I've run into. If I PRINT TO PDF the Sheet visibility is exactly what I've set it to. If on the other hand if the same Sheet is part of a set where I use the PUBLISH function the grey Classes print as Black. A bit of a pain & it means I have to Print to PDF those sheets & add them manually to a PDF set.
I'm using VW19 & wonder if this issue has been fixed in newer versions of VW?
Thanks
0 answers to this question
