Leon You Posted December 5, 2023 Share Posted December 5, 2023 Hi, our customer found that the hardscape he drew did not show correctly. After studying the case, we found the solution demonstrated in the screenshot. Why does the hardscape tool act like this? Is this a purposely setting? Besides, when the hardscape is clipped into sections, it seems hollow inside. Why is that? Quote Link to comment
Tom W. Posted December 5, 2023 Share Posted December 5, 2023 4 minutes ago, Leon You said: Hi, our customer found that the hardscape he drew did not show correctly. After studying the case, we found the solution demonstrated in the screenshot. Why does the hardscape tool act like this? Is this a purposely setting? Because initially the Hardscape is set to render by object in the OIP. If you change it to By Component it will show the components. If you select the tool then immediately specify a style, if that style has the Hardscape to be rendered by component then that is how the drawn Hardscape will look. Quote Link to comment
Leon You Posted December 5, 2023 Author Share Posted December 5, 2023 Thank you, Tom W. Quote Link to comment
