ReMatsu Posted December 5, 2023 Share Posted December 5, 2023 Hey guys, I tried to export a simple cube (1mx1mx1m extrusion) to L8 as MVR, checked the "Use 3ds format" checkbox (L8 requires this), and imported into L8, the object was there but without geometry. I tried the same exact thing on 2023 and it worked. Can you check this out please? This is a very important step in my workflow. Thanks, Renato Matsubara Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted December 5, 2023 Vectorworks, Inc Employee Share Posted December 5, 2023 @ReMatsu Can you DM me the VWX file and the MVR created in 2024? Also are you on a windows or apple computer? Quote Link to comment
ReMatsu Posted December 5, 2023 Author Share Posted December 5, 2023 When I was trying to recreate the problem, I discovered that if I keep the units in millimeters the export works, when I change to meters it does not. I think it is a scaling problem, the object is there but it's tiny. Here are the files. I'm having trouble uploading the MVR file, so I compacted it. It's in RAR. MVR_Export_Test_Win10_VW24_SP2.vwx MVR_Export_Test_Win10_VW24_SP2.rar Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted December 6, 2023 Vectorworks, Inc Employee Share Posted December 6, 2023 Its odd that the export works when set to mm but not m, the export process converts all dimensions to mm. I'll get a bug report opened and bring it to the dev teams attention Quote Link to comment
ReMatsu Posted December 8, 2023 Author Share Posted December 8, 2023 Oh, I see, so I think that's the problem, instead o converting 1m to 1000mm it is just accepting 1m as 1mm, that's why the object geometry is "invisible". Thanks for the bug report! Quote Link to comment
Charles Ford Posted February 18 Share Posted February 18 Hi, Im still having this issue. Has this been fixed and im missing something? Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted February 20 Vectorworks, Inc Employee Share Posted February 20 We are currently testing the fix for the document units not converting correctly. It should be in the next update as long as no issues are found with the fix 1 Quote Link to comment
