CW2020 Posted November 26, 2023 Share Posted November 26, 2023 Mind you this is occurring in VWX2022, but I'm working on a file where (from what I can observe) most all objects are 2D, Layer Plane, set to Top/Plan, and 2D Plan. But ~20% of the time the objects I create (from linework-to-symbols-to-text) convert to 3D objects and changes the view to orthogonal. Is this condition familiar to anyone? I thought it may be a legacy 2d issue, but welcome any input. Quote Link to comment
line-weight Posted November 27, 2023 Share Posted November 27, 2023 Do you mean the objects themselves are changing or do you mean the view you are looking at them in is changing? 1 Quote Link to comment
CW2020 Posted November 27, 2023 Author Share Posted November 27, 2023 (edited) Both. This also occurs (again, at the 20% range) when I simply group several items even; double checking all items are 2D items and that I'm on Layer Plane/Top/Plan/2D Plan. One or more will fly off to a different location. I'll locate the item. Then I'll select the item(s) and they are now 3D. This sometimes happens with symbols (which I see potential issues), but it also happens with something such as text or a polygon I just created and confirmed were 2D. It's a file setting (I didn't create the file). Because I can copy these items into a new blank file, and all is well. Edited November 27, 2023 by CW2020 Quote Link to comment
CW2020 Posted November 27, 2023 Author Share Posted November 27, 2023 (edited) Screen Recording 2023-11-27 at 11.56.58 AM.mov Edited November 27, 2023 by CW2020 Quote Link to comment
line-weight Posted November 27, 2023 Share Posted November 27, 2023 What I can see happening is that the "wide flange" object disappears when you put it into a group. It looks like you are putting it into a group that's on a different layer from the one it's in initially. Might that layer be set up with a different "scale"? Can't say much about the "things converting to 3d" bacause we can't see that happening in your screen recording. 1 Quote Link to comment
CW2020 Posted December 5, 2023 Author Share Posted December 5, 2023 The layer's the same, but good observation. I've gone through this exercise previously, but couldn't find the cause nor fix. I infer the file was copied over and then set up with no Saved Views, so I've gotten in the bad habit of going in-and-out of Viewports which I now think is the root of the issue. Thanks for your input though! Quote Link to comment
