Is it possible to cut a shaft through multiple slab objects at once? AEC-Subtract 3d object from slab doesn't allow you to select multiple slab objects. Is there another way around this?
It would be very handy to be able to link a whole shaft cut to one object rather than having to cut out the area for each slab object per floor, and would make coordination/updating shafts easier. Thanks!
TaylorK
1 answer to this question
