Plant View Effects - Polygon Display
Daniel OKane
Hello
I can't get a very important graphic to work, Plant View Effects - Polygon Display, which connects like plants with a dashed or other line type so that groups of like plants can be connected and tracked with a line - I've tried all combinations of settings in the Edit Plant Style 'Appearance' menu and nothing works.
Would anyone have a fix for this?
Thanks!
Hi @Daniel OKane, are your plants grouped? If they are, then you should be able to turn this on either in the tool preferences before you place the plant or in the Object Info Palette when the plants are placed. The plants can't be placed as individual plants.
If the plants are individual plants you're trying to combine into a group, first select the plants and right-click. Select 'Change Plant Grouping'. This will create a plant object with several plants in it and you can then add the polygon.Screenshot 2023-09-25 at 06.58.02.png
