nahekul Posted September 22, 2023 Share Posted September 22, 2023 How come "export layers as DXF/DWG layers" is grayed out now? We used to be able to select that option. Quote Link to comment
Jeff Prince Posted September 22, 2023 Share Posted September 22, 2023 You must have selected a Sheet Layer to export. If you export Design Layers, the option is available. That's the way it has been working. Quote Link to comment
nahekul Posted September 22, 2023 Author Share Posted September 22, 2023 It's when I try to publish saved views. (Using File>Publish) However, when I export the saved views individually it works. (Using File>Export) Quote Link to comment
Jeff Prince Posted September 22, 2023 Share Posted September 22, 2023 I guess I'm not understanding your issue. For as long as I can remember, exporting or publishing a Sheet Layer or Saved View has demonstrated this behavior. I just opened up 2021 to see if that was the case and it was, though the interface has changed somewhat since then. So, when was the last time and version you saw it behave differently than it is now? Quote Link to comment
nahekul Posted September 22, 2023 Author Share Posted September 22, 2023 You are correct. I must have misremembered how this works before. Exporting doesn't work for saved views when I try to select it. The only way this works is to go to each saved view and export it manually using design layers. Quote Link to comment
