Automate Data Tags in a Viewport
Fuge
Hey Guys...
Here I am again looking for something that's probably not doable..  But I'm throwing it out there...   either I'm not seeing a way to do it,  or can't find the functions to data tag an object.
What I'm thinking....
1.   Select a viewport.
2.  Run the script.....
3.  All objects within the selected viewport, assigned to a particular class,  are automatically data tagged...
*** when you have a bunch of viewports and everything in each needs a tag this would be a monster time saver ***
Any insight.. ideas... is appreciated...
Thanks
Dave
I'm working on a similar script at the moment, albeit in Python.
So far, I've gotten it near enough working in a design layer, and the next stage is to do it in VP Annotations. I'm not sure if VS:AddVPAnnotationObject would be enough, since it wouldn't know the handle of the specific object to be tagged.
I imagine you (we!) would need the handle of the viewport and then to traverse inside the Annotations Group using VS:GetVPGroup and find the handle of the object(s) in question.
To simply add a data tag, here's the small test function I've been using so far:
def tag(h):
    vs.AlrtDialog('Found Truss')
    newtag = vs.CreateCustomObjectN('Data Tag', 0,0, 0, False)
    vs.AlrtDialog('tag made')
    vs.SetPluginStyle(newtag, 'Truss Tag')
    vs.DT_AssociateWithObj(newtag, h)
So essentially - place the tag using CreateCustomObjectN, choose the style, then associate it with the object handle.
It generates all of them at the origin at the moment though, so I'll be working on setting the locations per tag soon.
Okay...  I should of realized that Data Tag is a pio.     Knowing that here is the concept and example.  Hopefully useful to others...   I plan to tweak this further, but it shows it can be done.    See the attached file as well,  the procedure is on a script palette with a VP to look at..
Thanks
Dave
Procedure Taggit;
VAR
 viewportHandle,VPGroupH, VPObject:HANDLE;
 VPName:STRING;
 ObjName:STRING;
PROCEDURE TagObj(H:HANDLE);
CONST
 TagName = 'Code Tag';
 LeaderAbove = 250mm;
 LeaderRight = 100mm;
 KVerticalOffset = 100mm;
VAR
 DataTagH,ObjectH,VPObject :HANDLE;
 StyleBoo, TagBoo,AnnoBoo :Boolean;
 TagX, TagY,x1,y1,x2,y2, pX, pY:REAL;
 ObjectTop, ObjectTopInSpace,  ObjectCenter, ObjectCenterInSpace, LeaderX, LeaderY :REAL;
BEGIN
   GetBBox(H,x1,y1,x2,y2);
   ObjectTop:=y2;
   ObjectTopInSpace:= (y1);
   ObjectCenter:=  (x2-x1)/2;
   ObjectCenterInSpace:= ((x2-x1) + x1) - ((x2-x1)/2);
   DataTagH := CreateCustomObjectN('Data Tag', 0 ,0 ,0, False);
   StyleBoo := SetPluginStyle(DataTagH,TagName);
   TagBoo := DT_AssociateWithObj(DataTagH,H);
   AnnoBoo:= AddVPAnnotationObject( viewportHandle, DataTagH);
   DataTagH:= Lnewobj;
   LeaderY:= ObjectTopInSpace+LeaderAbove;
   LeaderX:= ObjectCenterInSpace+LeaderRight;
   HMove(DataTagH, LeaderX, LeaderY ); {Leader above center of object }
   SetRField(DataTagH,'Data Tag','__RefOffsetX',Num2StrF(Round(ObjectCenter))); { Move horizontal }
   SetRField(DataTagH,'Data Tag','__RefOffsetY',Num2StrF((ObjectTopInSpace-KVerticalOffset))); { Moves vertical }
   SetRField(DataTagH,'Data Tag','Horizontal Position','Right'); { Default side the leader is placed }
   SetRField(DataTagH,'Data Tag','World-based','False');
   ResetObject(DataTagH);
END;
BEGIN
  ViewportHandle := LSActLayer;
  If ViewportHandle=NIL THEN
  BEGIN
    AlrtDialog('Select a viewport!');
    Sysbeep;
    END ELSE
    BEGIN
      VPGroupH:= GetVPGroup( viewportHandle,2);
      VPObject := FInGroup(VPGroupH);
      { The record criteria, class, etc to tag }
      ForEachObject(TagObj,((R IN ['Nimlok DB']) &(C='STEP-1') & (T<>LIGHT)));
      VPObject := NextObj(VPObject);
      UpdateVP( ViewportHandle);
      Redrawall;
  END;
END;
Run(Taggit);
AutoDataTag.vwx
  • Like 3
  • 1 month later...
Hey KingChaos,
See the attached...     The attached is saved back to VW22...    But not tested there...
HTH ..  A lot more development is being worked on for this...  Something I'll post in the future..
Procedure Taggit;
VAR
 VPName:STRING;
 ObjName:STRING;
CONST
VAR
BEGIN
   ObjectTop:=y2;
   DataTagH:= Lnewobj;
END;
BEGIN
  Layer('View-1');  { Example  Go to the layer you want by its name }
  ViewportHandle := GetObject('MyViewPort');  { Example - Get the Viewport you want be name, giving you a handle to it  }
  BEGIN
    Sysbeep;
    END ELSE
    BEGIN
      Redrawall;
  END;
END;
Run(Taggit);
AutoDataTag_v2022.vwx
  • 1 month later...
