ETC Source 4 shutters in Vision
I do not believe there is a way to do this with MVR yet.
What you suggest would work, but there might be an easier solution. You can export your conventionals with shutter cuts into an ESC and everything else into the MVR. You can then open the MVR and merge in the ESC file.
I hope this helps!!
