DDD Posted August 2, 2023 Share Posted August 2, 2023 Hi, I am having questions about site modeling, please see attached file (2023 Landmark) -my goal is to model as below: -I modeled the retaining walls and pads on one side, it goes well. -But when I mirror the pads to the other side, the model is messed up, any thing I did wrong? Thanks in advance! retaining wall.vwx Quote Link to comment
Popular Post Jeff Prince Posted August 2, 2023 Popular Post Share Posted August 2, 2023 @DDD How about changing the modifiers for your cheekwalls to retaining modifiers, deleting your riser/retaining modifiers, adding tread/pad modifiers? Attached is an example. rw modifiers.vwx 6 Quote Link to comment
DDD Posted August 3, 2023 Author Share Posted August 3, 2023 @jeff prince You are the legend, I never thought about this solution. Thank you so much! 1 Quote Link to comment
Jeff Prince Posted August 3, 2023 Share Posted August 3, 2023 10 minutes ago, DDD said: @jeff prince You are the legend, I never thought about this solution. Thank you so much! Happy to help. FYI - I typically just do a single retaining modifier to carve out the whole area for a stair set and cheek walks on small landscape sets like these. It makes it faster to edit the modifier if your stair pitch or position needs to change 🙂 3 Quote Link to comment
